Freeview HD updates ?
Portoman
42
Hi
I just bought a tv with built in tuner and it has some HD channels on it. However, I also have a separate freeview recorder but when I update the channels on it, it doesnt pick up any HD ones. Is it because the tuner is in the HD tv and the recorder isnt ?
professorhat
992
22
18,895
Yes, the HD tuner is in the TV so only the TV will pickup the HD channels. To get Freeview HD on your recorder, you'll need to purchase a new one with an HD tuner in (like the Digital Stream DHR8205 or the Humax HDR-FOX T2).
