Foxsat HDR
motley
202
My unit has started to provide subtitles whenever you pause a program, if you record it and play it back no problem (or subtitles) I have tried software updates.
Any other Foxsat user suffering from this?
daveh75
572
7
18,895
It was a known bug, that effected some boxes last year, but was fixed with a firmware update AFAIK - Are you sure you F/W is upto date?
From what i can remember though, either toggling Subtitles ON/OFF in the menu, or doing a factory reset should cure the issue...
daveh75
572
7
18,895
motley:Thanks but will a factory reset wipe the hard drive?No. Your recordings are safe, but a reset will delete any recording reservations/series links, so i'd make a note of them before doing so...
ASK THE COMMUNITY
