Foobar album art bug? or am i missing something
kena
104
Album art is showing okay for all my albums (copied 700 so not file structure problem) apart from two , The Cure/The Cure & Lloyd Cole/Lloyd Cole. An image The Cure.jpg & Lloyd Cole.jpg are in their respective folders anyone else came across this , I'm on verge of puting query on Foobar forum as I can't seem to crack it PJ or another Foobar user any ideas?..
Edit Img added...Doesn't think any image their as its adding/picking up my modified no album art img..
Have you tried renaming the JPEGs concerned and seeing what happens?
All my artwork is named Folder.JPG and does not follow the name of the containing folder yet the artwork is displayed.
Otherwise is it possible that the JPEGs are corrupted and cannot be shown and therefore downloading again may fix?
adamshaw:
Curious earlier today I renamed The Cure via Foobar properties tagging to The Cure 1 then back to The Cure and the album art displayed - it hasnt for Lloyd Cole but obviously points to a tagging issue/corruption. Will delete/redo Llloyd tomorrow to see if that resolves.. JPEGs are fine , Cheers Adam
Re rip of disc , sorted so a tag issue somehow... Now to next challenge , keeping Classical separate from everything else...
PJPro:Create a playlist which excludes classical.
Wanting it as album list panel so can just do view by Classical or view album/atist for everything else , need if %genre% into album list options I reckon.
In case anyone is looking to do something similar with a Genre the following code can be used/modded
Puts Classical first (Note space at second classical )
$if($stricmp(%genre%,Classical), Classical|)$swapprefix(%album artist%) - ['['%date%']' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
Exclude Classical
$if($not($strcmp([%genre%,Classical))],,$swapprefix(%album artist%))- ['['%date%']' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
Show only Classical
$if($not($strcmp(%genre%,Classical)),,$swapprefix(%album artist%) - ['['%date%']' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%)
This is useful stuff kena.
I've not really investigated the scripting potential of foobar....but it would be useful to exclude certain genre from my daily listening, e.g. Christmas Carols and Classical, as you have. Thanks for the head start.
PJPro:This is useful stuff kena. I've not really investigated the scripting potential of foobar....but it would be useful to exclude certain genre from my daily listening, e.g. Christmas Carols and Classical, as you have. Thanks for the head start.
PJ Have you looked at changing the buttons? another very easy improvement to make , some great ones out there just note post (Page7) about if you get an error loading you need to change to ui.columns 0.1.3Beta1v7 export them then import back to your current ver.
