Floorstanders as Rear speakers
Hi all,
Too late for Speaker Wiring changes so am stuck (and relatively happy) with what I have in terms of my now hardwired sitting room…. I am a bit novicey on this stuff, so any advice appreciated…
The set-up will be a 6.1 with Front Left, Front Centre & Front Right and then Rear Left, Rear Centre & Rear Right. All the Rear Speaker wires are chased to floor level, so I will have 3 Floor standers as my Rear Speakers…Will suit the room too in terms of looks anyways as Sitting Room is largish and so can take (looks-wise) 3 Rear Floorstanders.. Front will have same Floorstanders for Left & Right with a small Mission M3C2i Center speaker under the TV…
Have decided on Mission M34i as the Floor Stander Speakers, so I wanted to know is there anything I will need to be aware of or have to do with these in terms of the use of them as my Rear Left, Rear Centre & Rear Right speakers…..???
I like the looks of them, and they will keep herself happy as well, so please say all is well….!! Thanks
Other than careful positioning and angling of the surround left and right (the rear centre is pretty simple!) you should be fine. It'll make a pretty good setup for multi-channel music as well I expect as that's full-range through every channel.
the_lhc,
Thanks for putting my mind at ease as I was committed to ordering my 5 Mission M34i speakers and the centre as well, so phew as in it should all work okay...As I said, It will look well but that would be ****** all use if it didn't blow the socks off me when no one else is home....!!
Will be running them on a Denon 1910 and have been offered a Wharfedale 10.SX as a suitable sub, so hopefully it will do the business...
thanks again
