Good point, I'm guessing iphones don't support FLAC (Macs don't, not natively anyway), in which case maybe consider ALAC (which is kind of an Apple FLAC equivalent).Lee H said:I use FLAC, but I see you also have an iPod. I run 2 libraries, one in FLAC for sonos and one in ALAC for my iPhone. Using something like dbPoweramp this is failry easy to do. Also, MediaMonkey can transcode on the fly to another format (keep the original FLAC but put an AAC copy on your iDevice) but I found it very slow
MajorFubar said:Good point, I'm guessing iphones don't support FLAC (Macs don't, not natively anyway), in which case maybe consider ALAC (which is kind of an Apple FLAC equivalent).
You can't: there is no iso9660 filesystem on an audio disc.dannycanham said:If you really wanted to be wierd about it; rip everything as ISO and use a drive emulator to play all your music as virtual versions of your original CDs.
John Duncan said:And anybody who says they sound different is...in disagreement with me ;-)
Any difference, if not placeabic, could only be down to the effects of real-time decoding, because it's quite easy to prove that an original WAV and a decoded FLAC of that WAV are absolutely identical.Thaiman said:John Duncan said:And anybody who says they sound different is...in disagreement with me ;-)
I thought that but now I am not too sure. Is it just me that think Wave files sound fuller?
MajorFubar said:Any difference, if not placeabic, could only be down to the effects of real-time decoding, because it's quite easy to prove that an original WAV and a decoded FLAC of that WAV are absolutely identical.Thaiman said:John Duncan said:And anybody who says they sound different is...in disagreement with me ;-)
Blackdawn said:I'm happy with WAV. Not sure what is meant by tagging? But WMP labels all the albums so I don't need to. If you have MAC maybe its a different story.
Blackdawn said:But WMP labels all the albums so I don't need to.
The_Lhc said:Blackdawn said:I'm happy with WAV. Not sure what is meant by tagging? But WMP labels all the albums so I don't need to. If you have MAC maybe its a different story.
It'll be a different story if you play the WAVs on anything other than the PC you've ripped them on, as the "labels" won't travel with them.
