FLAC music stream
alializadeh
54
hi
i'm a huge fan off FLAC music files and would love to play them on my Marantz PM6004 with 2 B&W M1's.
here is the probem: i store all my FLAC music on my laptop or external usb 3.0 hard drive, BUT i always have to stream it by my laptop.
somebody told me that the sound coming from your laptop is not pure FLAC 16bit , 192khz sound, whatever your filetype is or your sound setting, is this correct?
i'm looking for something where i can store my huge collection and stram it to my ampifier. a sort of sound card but with storage...
any idea? or what i should do to get the best sound out of my files, hard drive, laptop?...
thanks
MajorFubar
690
6
Just so we're all singing from the same hymn-sheet (ugh!), FLAC is not an audio format, it's a lossless storage format, designed for storing audio files of various resolutions and bitrates. So when you say the output from your laptop isn't 'pure FLAC 16bit 192kHz sound', there's no such thing, because FLAC doesn't determine the quality of the audio. if you have 192kHz hi-res files on your PC stored as FLACs, then as far as I know, your PC should be able to output them bit-perfect to an external DAC, though you might need a bit of jiggery-pokery to bypass Windows' automatic reprocessing, which is possibly what your friend meant.
With regards to using another source in place of your PC, there are streamers which will store and play FLAC-format audio files from either built-in hard-drives or external hard-drives on your home network. This would take your computer out of the equation. I'm sure someone with more knowledge than me will come along with some suggestions.
philbirch
6
How are you getting the sound into the amplifier? An external DAC or the computers sound card?
It sound's like you need an NAS with a Network Streamer if you want to take the laptop out of the equation. Some streamers might be able to mount the USB drive directly removing the need for the NAS. I know Squeezeboxes did, but they've are no longer on sale. :-(
Overdose
279
alializadeh said:
hi
thanks
Have a look at a Roku Box and a NAS for storage.
RobinKidderminster
582
Just gonna sell my Seagate Theater + in favour of a WD TV Live. £80 + usb hdd/stick gives a cheap media streamer for videos, photos ans FLACs. Thru hdmi all sounds pretty good tho others may be ablw to compare its sq with other kit?
I think uncompressed flac comparea very well with cd thru bdp.
daveh75
I'm guessing you've never used one then?
As much as I like my Rokus, they're no music streamer and would never recommend one for that purpose.
You need the TV on for starters, they only have HDMI output or analogue out via a 'custom AV cable' (3.5mm mini-jack to stereo RCA + composite video) and SQ is poor, as is file format support so won't do high res flac like the OP wants.
Overdose
279
daveh75 said:
I'm guessing you've never used one then? As much as I like my Rokus, they're no music streamer and would never recommend one for that purpose. You need the TV on for starters, they only have HDMI output or analogue out via a 'custom AV cable' (3.5mm mini-jack to stereo RCA + composite video) and SQ is poor, as is file format support so won't do high res flac like the OP wants.
Interesting, so they dropped the optical output then?
The remote app can be used to control the devide headlessly though surely?
Did the OP say the he had or wanted high resolution music?
daveh75
Did the first gens have then? The LT, XS and Roku 3 don't
Nope. The app is literally just a remote keypad and keyboard, so there's no way to view or select media without a display
They're primarily streamers for online video, and other features are provided by third party channels, so no real reason for Roku to add the functionality to the app I guess.
He mentions 192khz flacs.
AnotherJoe
407
Right idea with streamer but wrong example.
Something like a WD Live ( or similar) would be better as it supports DLNA and FLAC. So you could use a phone/tablet/pc to control it if you didnt want to have the TV on.
You bascially want a streamer that supports flac and is certifed as a DLNA renderer so it can be controlled by a remote device.
Overdose
279
What he mentioned was this...
"somebody told me that the sound coming from your laptop is not pure FLAC 16bit , 192khz sound, whatever your filetype is or your sound setting, is this correct?"
..and it's not the same as asking for high res music files. It appears the OP is just unsure as to what FLACs are and how they relate to music playback.
data:image/jpeg;base64,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
Next to the DC input can be seen the opticla output socket.
Granted, the new box appears to be more limited in connectivity.
AnotherJoe
407
RobinKidderminster said:
Any comment on SQ from a flac thru WDTV live? I have yet to open the box.
If you are using digital output (optical/hdmi) on the WDTV then the SQ depends solely on the connected amp/dac/speakers when playing lossless codecs.
RobinKidderminster
582
Thanks AJ. Guess I kinda thought that but was worried in one review saying the sound was poor. My Seagate seems to provide a decent flac to my amp and trust that the WDTV will perform as well. Cheers
