Fixing points for Q Acoustics 1010i please
Can anyone help me with details of the above speakers? I am thinking of buying the Q Acoustics to form part of my proposed new home cinema package. I have a pair of Alphason RS10/S stands for my rear speakers and hope to use them for the 1010is .
Although the stands aren’t the greatest I have seen, they are telescopic as I need to have a minimum height of at least 108 cm (421/2in) to the bottom of the speakers and they will do in the interim till I can afford better ones. If anyone can offer any advice or needs further information please contact me.
Thanks in anticipation.
I've just bought a set of 1010i's for my surround sound system. I've mounted the rears on wall brackets. The speakers sit on these brackets and hold secure via a single screw on their base.
Hi PM,
Thank you for the reply and information. Is it possible to give me any dimensions? for example the distance from the back of the speaker to the single fixing point. Thank you once again.
Regards Williaml
