First step into Blue Ray
Its time i got hold of a Blue ray player to go with my 1yr old 42'' Panny plasma.I would like a Panasonic Blue ray so i can use the VIERA link.I can get hold of a BD35 for £130 or a BD60 for £160 i know the BD60 is the newer model but is it that much better.So which would you plum for guys.
They are both identical in picture and sound quality. The BD60 has an added feature of Viera Cast where you can access YouTube.
I have my computer to do that, hence my decision keep the BD35.
ValianTX:
What he said.
And its a moot point, but its Blu-Ray not Blue Ray
lobby
161
Easy choice for me go for the BD60 not a huge improvement, but with newer models any problems should be fixed easier, a bargain at Play.com £174.99 but waiy you get 7 free films with it seems a great deal, but be quick because the deals on the Sony are dissappearing and there's a chance the Panny will go the same way, No brainer imho.
Deleted member 2457
barnsleydave:
gel:Stingray
What?
It's kind of hard to explain Barnsleydave Blue-ray what ryhmes "stingray" blue-ray - Stingray.
Do you get it now?
Deleted member 2457
ElectroMan:
I suppose anything can happen, but Stingray on Blu-ray would be great!
If they can do pinochio (think that's spelt right) on blu ray then I don't see why not?
