- Jun 26, 2009
- 1
- 0
- 0
Looking for some advice in my maiden voyage into home cinema.
I have a small room (10 ft x 8 ft) which houses a 32" LCD and is only used for watching TV.
I am looking for an amp and speakers and am willing to spend up to £1000. I was initially thinking of the Denon AVR-1910 with the Kef 2005.3 eggs as the amp seems to get good reviews and the speakers need to be small. I have been to a couple of retailers and they have managed to confuse me more with their advice. One said the KEF 2005.3 would be overbearing and suggested the KEF 1005.2 instead, the other said that he did not rate the 1005.2 and would go for the 2005.3 which would be fine and supply a superior sound. Both retailers suggested the Onkyo 607 as an amp! Not sure that auditioning would make my choice any easier as I think the room size / acoustics will have the biggest impact on the sound.
I guess the question is, in a room this size is there a price point where you are not going to benefit from spending extra. Is £1000 overkill,should I buy cheaper components and save some money, or would I regret this.
Thanks in advance for any help.
