Hi there,
I'm in the process of getting my first decent starter hi-fi setup, but due to limitations of comparing different set-ups in stores (the stores here in west-siberia have only limited stock and none of the stores seems to cover all those brands I'm interested), I would be grateful for your opinions on a few questions.
I've limited my setup to the following options (and budget):
Amp: Rotel RA-12 OR Marantz PM6004
Cd player: Marantz CD6004 or similar
Speakers: Monitor Audio BX2 OR Kef Q300
Now, my set of questions would be:
- Do you think the Rotel RA-12 would pair better with the BX2 or Q300 speakers?
- How about the Marantz PM6004 amp, it obviously pairs well with the BX2 (as said in the earlier WH review), but how about with the Q300?
- If the Rotel RCD-12 would be a bit out of the budget, which 'more budget' CD player would you recommend to go with the RA-12?
All in all, I guess the question would be: should I go with the Rotel RA-12/some budget CD player/Q300 set-up, OR the Marantz PM6004/CD6004/BX2? Any other ideas?
The problem is that I can't test different set-ups since the stores here sell either Marantz, KEFs, Rotels or Monitor Audio, but none sell all of them.
I listen mainly jazz, some pop and occasionally classical. The room where the set-up will be is app. 25-30m2.
I salute you in forehand for all the advice and tips,
Have a pleasant rest of the week,
Pauno
Pauno
