- Aug 10, 2019
- 2,556
- 5
- 0
It arrived today and these are my first impressions:
First up, it looks lovely! build quality is excellent and it looks like a fine addition to the set-up.
Installation was as easy as pie - the laptop picked it up right away and defaulted it as the audio hardware. No drivers to install or anything. There are 3 LED's on the front panel - blue = power; red = not installed as soundcards; green = audio signal being processed.
As a comparison, I ripped a Kraftycuts CD to itunes at 192kps, then popped the same CD in the CDP. The first thing to note was that full volume on tha laptop volume control and itunes corresponded exactly to the lineout volume of the CDP, which was pleasing.
The CD had a very slight edge on separation, but frequency range and tonal quality seemed identical to me. The difference was slight, and only really noticeable by prolonged flicking between the two sources.
Now then, there are 3 points to note here:
1) I haven't bypassed windows kmixer, so there should be some gains to be had here
2) The unit was box-fresh and using the supplied cables, so a little more running time and it may settle down
3) The track was 192kps - not lossless - which will have some impact
All told, it was a worthy purchase. I'm pretty certain that by addressing the 3 points above I'll have it running as good as, perhaps better than, my NAD 521i.
One final thing - it is a vast, vast improvement on the lappy soundcard. Like night and day!
