fishyfella:what problems did you have ? by any chance was it due to too much noise ?
Nope. Both boxes were well ventilated. The first box suddenly came up with "no signal being recieved", the engineer came out and tested the signal on both feeds and they were fine so he replaced the box. The second box only appeared to have one working tuner since when you tried to record a programme then watch something else at the same time you got "no signal" again. Oddly, the signal test on the Sky box said both tuners had almost full strength, and you could watch terrestrial channels whilst recording.
daveh75:no your not unlucky, dunno if your aware but when sky come out to replace your box, they dont replace it with a new one, you get "a service box" so basically its a box that went faulty, and then supposedly repaired, but what tends to happen is they bench test these boxes and if theres a fault its repaired, but trouble arises when they get a faulty box back,then they bench test it and the fault no longer appears to be present,coz that box will be sent straight back out as a "service box", as will your faulty box when its replaced, this is why you end up with customers going through numerous boxes
I had suspected that might be the case when I saw the replacement box just came in a plain cardboard box and not the Sky HD box.
