Faulty Roksan Kandy 3 amp
paulsue38
55
I have lost sound from all sources on my Kandy 3 amp (original version not the new one). I suspect that the amp has detected a fault and the protection has been activated. I have power lights for all sources, (red and not yellow) for those that know this model. The volume control works with the remote control.
I found the fuse under the power lead which looks ok and I suspect this is the power fuse; as I appear to have ‘power’ this does not seem to be the problem? I have opened up the machine (not under warranty) to try and locate the fuse for this but can’t find any. Is there anyone out there can advise?
Best wishes
Paul
If I were you I would just send it back to Roksan so they can repair it. Unless you actually know what you are looking for/doing then I'd leave the tinkering to the experts.
paulsue38
55
Thanks for the reply. I have located two protection fuses that have blown. I have taken to a local electronic surgery to repair (they are soldered in) . Hoping that nothing else has gone. I figured that given the weight of the amp it would have been over £40 to send and return and that it may be more cost effective to repiar locally. It is out of warranty so worries about this. In the meantime i have borrowed an old A/R Cambridge A60 from my brother. It's great easily driven and lovely midrange!
Paul
Yeah, I think that is for the best. I understand where you are coming from in terms of shipping it back to Roksan - it's a heavy brute.
I had a kandy mk3 liii and it developed a fault within a few months of owning it. Audio only coming out of one channel then went crazy (sounds sporadically coming out of different channels at very high volume) when I tried to adjust volume. I've read about quite a few cases relating to issues with that particular amp.
Very happy with my Caspian though. :)
ASK THE COMMUNITY
