Fatman iTube
PJPro
274
I'd like to use the Fatman iTube with my Aego M speakers. I was thinking along the lines of connecting the satellites directly to the Fatman and using the subwoofer as simply an active subwoofer.
If the above is feasible, how do I connect the Aego M subwoofer to the Fatman? I could simply use the line out but that would mean I would need to turn up the subwoofer as I turned up the Fatman (wouldn't it?). Can I connect the subwoofer via the speaker connections on the back of the Fatman somehow?
Perhaps I am completely barking mad. Happy for you to say so (with justification).
Incidently, if anyone is aware of a similarly small amp I could use as an alternative to the Fatman I would be grateful if you posted a reply.
