Fatman iTube & Sony Turntable
Just looking for some advice. Sorry, I am an amateur when it comes to this stuff. Can you link a turntable onto a Fatman iTube 182 amp?
On my turntable there is the usual right and left input and the grounding connection, but there is no grounding screw on the amp. Obviously, I have no sound (as a result of this). Is there anyway around this?
Thanks in advance.
John
fatboyslimfast
158
Hi John,
Does the Fatman have an input specifically marked "Phono"? If not, then you will need a phono pre-amplifier.
The lack of sound is probably more to do with the lack of gain in the amp, rather than the lack of a grounding screw.
I've given suggestions of this in another thread - http://community.whathifi.com/forums/t/569662.aspx.
Hope this helps,
Thanks for the advice Mr. Slimfast.
There doesn't seem to be any phono input on the amp. Will look into the Phono pre-amp as you have said to see if this solves my problem.
John
