toyota man said:Hi Cno how are you I had a quick look at your link and that was enough 🙂
BenLaw said:What is it about these that mean you are not open minded? Surely you need to use them and listen to make a decision? Even if they didn't work for you, surely they may be system / room dependent?
CnoEvil said:BenLaw said:What is it about these that mean you are not open minded? Surely you need to use them and listen to make a decision? Even if they didn't work for you, surely they may be system / room dependent?
Why not get some and let me know how it goes........I'll be breathless with anticipation.
CnoEvil said:Seen this link on PFM: http://www.machinadynamica.com/machina31.htm
alchemist 1 said:CnoEvil said:Seen this link on PFM: http://www.machinadynamica.com/machina31.htm
Are the crystals A/C or D/C ? ..............:?
BenLaw said:CnoEvil said:BenLaw said:What is it about these that mean you are not open minded? Surely you need to use them and listen to make a decision? Even if they didn't work for you, surely they may be system / room dependent?
For some people, a lot of the aftermarket products you believe work are in the same category as these products (products that objectively can't have an effect, albeit a user may subjectively experience one), so the questions had a serious basis. Perhaps just answer the first one for me?
CnoEvil said:BenLaw said:CnoEvil said:BenLaw said:What is it about these that mean you are not open minded? Surely you need to use them and listen to make a decision? Even if they didn't work for you, surely they may be system / room dependent?
I've probably got it all wrong and am doing them an injustice.
steve_1979 said:CnoEvil said:Seen this link on PFM: http://www.machinadynamica.com/machina31.htm
I've tried them and in my subjectively listening tests they make the sound a bit hard and gravely. The treble sounded so grainy that I had to grit my teeth.
I also took some rock solid objective measurements which showed that they make no dfference to the sound. So you could say that I'm between a rock and a hard place when it comes to deciding if these magic pebbles work or not.
DIB said:Somebody mention Pebbles?
BenLaw said:I've seen posts on (other) forums about these types of products, people genuinely praising them. Does this mean the products work or does it mean something else?
Your thread title is 'even I have my limits'. Without simply saying 'these pebbles' are you able to help us with how you define those limits?
CnoEvil said:BenLaw said:I've seen posts on (other) forums about these types of products, people genuinely praising them. Does this mean the products work or does it mean something else?
I thought this place could do with a little light hearted banter.......and since (as far as I know) nobody on here uses them, it isn't controversial.
......and It looks like you just proved me right, You have a wicked sense of humour, so it would be nice to see it a little more often.![]()
BenLaw said:I'm not sure you'd have liked it if someone had started a thread laughing at, for example, mains products. Whether there is a user of the product on this forum makes no difference - it is either acceptable or not to derive humour from a product that makes claims that confound science and yet have subjective proponents.
Anyway, if you choose not answer any of the questions I posed on this thread you'll have to forgive me if I refer back to your OP when appropriate.
CnoEvil said:FWIW. The thread title was gently taking the P out of myself.
