I want to start using vinyl records so I am looking for a good setup. I need some advice on entry-level turntables. I want a fully manual (or semi-automatic with auto-off), belt-drive, needle upgradability (preferably to a diamond tip needle), lightweight arm, and (not as important) wood-finish (unless that is not good for listening). What would you recommend?
I am on a budget, I understand that you get what you pay for, but considering that if I drop $300 on a turntable that I have to then buy all the additional parts for the setup, that is way to pricey. Perhaps something with speakers in it, or the pre-amp in it, or one that is cheap enough where I would be able to not go broke buying the entire setup. Like I said, I am wishing to start, so I do not want to invest a huge amount on something that I may not stick with, but then again I do not want to cheapskate with it because then the poor quality will most likely make it difficult to stick with it. I wish to find a balance. Any thoughts? Ideas?
