Entry level Naim Audio streamer?
skippy
68
Hi
Anyone out there know if Naim Audio is planning to release an entry level uniti or unitiqute without the amp and CD?
Ajani
42
skippy said:
Hi
That product has been requested from when the UnitQute debuted (if not before), but Naim seems to be in no hurry to produce one. Eventually they'll probably have to.
skippy
68
I'm toying with the idea of a Sonos connect plus (eventually) a decent DAC. An entry level streamer from Naim (and an android app) would be very tempting, it would also provide a steady upgrade path
Ajani
42
An entry level streamer would be great for someone with a Nait 5i. The other option is to get a DAC and Squeezebox (or Sonos as you suggested). The trick would be to find a DAC that has synergy with the Nait.
manicm
For all practical purposes the UnitiQute is Naim's entry-level streamer. After that you're looking at the ND5 XS, and don't ever expect them to release a dedicated streamer below that cos they have 2 further up, plus there's the original Uniti, and the new SuperUniti.
And that is your Naim lot.
