Electrical Popping Sound
Hi
(System detailed below with two Tacima CS929 surge protectors)
Everytime i turn Sky HD box off i get an annoying electrical popping through all seven channels. I only get this when turn the Sky box off and i'm assuming its a poor earth. Has anyone else had a similiar and how did yoy resolve, i've reorganized all cable behind the system, changed between co-ax and optical digital cables and swapped the QED HDMI-P cable around with no affect.
My last line of though is to run an earth directly of a casing screw from the Sky box to a plug's earthing pin.
Any better ideas please?? It's not the soundest crack but it is the most annoying and i think my other half is getting fed-up with me behind the TV
Vance
My cd player 'pops' but to get around it I simply select another source on the amp before turning it off
Similar threads
