wilro15 said:I'm struggling with dodgy electrics right now too where my RCD keeps tripping out. Turns out to be a power cable in the wall is damaged - as a result it only delivers 50 volts to the socket instead of 240. So when I use any more than a tiny amount of power it trips out. Expensive to fix though as I don't know exactly where the fault is!
Overdose said:Until the OP explains concisely what is wrong, what he wants to do and why, no useful assistance could be given.
50V is entirely possible on mains wiring, but would be more likely on the earthing circuit that did not correctly terminate at earth, or in conjunction with a neutral fault. The greater the continuous length of earth wiring not grounded, the greater the potential for higher voltages being induced.
smarkgee said:hi guys thanks for the replies.
I'm not asking for advice about ring mains or other stuff.
I'll clarify. It is for EMC/RFI shielding. so i want to attach earths as outlined - I'm just not sure exactly how to do it. It's the HOW TO that I need the answer on not the WHY DO!!
RobinKidderminster said:An irrelevance maybe abacus but (a) what cable damage would increase its resistance and (b) the voltage will remain 240v but the current reduced with higher resistance I believe
pauln said:smarkgee said:hi guys thanks for the replies.
People are trying to tell you that you don't need to "extra" earth your appliances.
If they need earthing they will be already earthed via the mains supply earth which will be connected to the chassis internally. This is to prevent the chassis getting "live" and electrocuting you if you touch it.
AFAIK earthing and shielding for RF/EMI are two different and totally separate things.
I think you are getting worked up about a non issue.
