DVD player caput?
Alec
478
My dvd player has started showing stuff in black and white. I've checked all obvious connections - i think. anyone else had this problem? is it cream crackered?
Alec
478
i assume thats a yes its beggared. if anyone can reccommend a cheap n cheerful dvd player (with divx would be great but non essential) to keep me going til i get a br player...
Andrew Everard
1,878
Toshiba SD370, for about £40 or so?
But it does sound like a loose connection or a setting that's switched to NTSC or something - how's it connected and what to?
Alec
478
Thanks! Its just connected to my panny crt by scart i think. As you may know from the past, connections are a huge weak point for me. Ive not knowingly changed any settings. Just double checked to be sure, and the prob hasnt magically fixed itself. damn. its an irritating time for it, as i was going to upgrade my TV and disk player later in the year or even early next. Thats why i just want a cheap job as ive a number of other bigger budget things to do before then.
John Duncan
2,033
27
19,720
Take the scart out and put it back in again, it's usually that. Check it's set to PAL and not NTSC and that the video outputs aren't something stupid like S-Video (it might have booted itself up to defualt settings by magic - happens to my humax pvr).
Otherwise, off to tescos for a toshiba.
Alec
478
And a quick fiddle with the settings has done the job! My REM Perfect Square dvd looks as, er, perfect as ever! Many thanks guys!
Alec
478
oops. sorry. its working, but the "video out (AV/Component)" says S-~Video/YPbPr...that right? EDIT *** Sorry again. answered my own question. it only looks right on that. and the "ntsc output" bit is set to PAL 60. Thanks again folks.
