- Sep 24, 2015
- 1
- 0
- 0
Hi, 1993 I went into Sevenoaks hi fi and got myself an Arcam Alpha 9 amp, 2 acoustic energy 309 speakers and a couple of Technics 1210s. The technics are still going strong and so are the speakers and the amp aside from the well known selector switch issue...but they are not really been used because i dont have a cd player atm. Now I've purchased a 47LB730V and an xbox and I want to hook these up to an amp and also be able to stream tunes via bluetooth. What I can't decide is whether I :1. Buy a dac and a bluetooth streamer and use the existing amp and speakers2.Buy a new amp. I went into Sevenoaks and they recommended a Rotel RS-12, and looking around I found the Marantz PM6005 but I would still need a bluetooth streamer if I went with that - I'm also not sure if these would go with my 309's3. Do something else I would be connecting the tv and the xbox as a cd player, and to primarily stream music from my laptop as well as connect my technics (although not too often as the better half isnt too keen on my oldskool tunes 🙂 ).If I am connecting the tv is it a waste if is only 2.1 not 5.1 for example.I have to say I am a bit stuck so any pointers would be great .....but either way I dont want to spend more than £500 ish.Sorry for the long post!Thanks
