- Aug 10, 2019
- 2,556
- 4
- 0
Hi, I use a laptop as a source playing all my music from iTunes via an external hard drive. The laptop runs via a MF V-Link II from USB and then into a DAC via the optical output on the V-Link. I want to continue using iTunes as the media player rather than e.g. JRiver because a significant number of my tracks are protected AAC which cannot be uploaded into JRiver etc. I'm assuming that even using the V-Link the music from iTunes is being processed by Windows before being output to the V-Link/DAC and I don't think I can achieve bit perfect output from my Windows based setup unless I use a different media player. The laptop source I currently use is a Toshiba Equium U400. I would appreciate your comments on 4 questions: 1. Are my assumptions above correct? 2. Can I optimise my current setup to achieve bit perfect without using an alternative to iTunes? 3. Does the laptop make a difference? I'm thinking of buying a MacBook Pro anyway (for using while I am playing music with the other one) but now beginning to think I would be better using that as the music source and the Toshiba for web browsing etc. 4. I believe you can buy a solution for iTunes which produces bit perfect output but this is only available for Macs? Thanks
