Does iPod charge at the same time it is playing via a USB port on a hifi?
Apologies for the previous 2 posts - my message posted twice and incomplete!
I'm thinking of buying a Denon mini hifi system with CD player and USB port for an iPod/MP3 player (RCDM38DAB). I'd just like to know whether my iPod will charge at the same time it is playing when plugged into the USB port.
Thanks!
For a definitive answer contact Denon support,
http://www.denon.co.uk/uk/pages/home.aspx
Having looked at the user manual I would say yes it will as the front USB socket is marked as 5 volt 1 amp which to me means it can support that current draw and so conforms to a normal USB standard and would charge not just an iPOD but also be OK with say an external USB HDD and so on.
Well I know I replied to this earlier today... a detailed reply to so I have no idea why it 'aint showing now 🙂
The quick answer is yes, it should charge the iPod as the USB port is capable of supplying 5 volts at 1 amp just like one on a PC.
Thanks very much for your reply! I went ahead and bought the stereo and am very happy!
