In the spirit of open-mindedness, I would like to try the Cyrus cable that they recommend for my amp. It is a single core copper cable, of less than 1mm dia. per conductor. It appears virtually the same, if not the same, as DNM cable. The only thing is, I don't particularly want to pay c. £25/m or so, or buy expensive connectors to only find out it doesn't outperform what I already have.
My question is, and it really isn't meant to be provocative, is why will it sound different from single core copper bell wire of an equivalent diameter? And will it be OK to just terminate it using bog-standard connectors from Maplins (grub-screw type, as I don't solder)?
Thanks in advance.
Thanks in advance.
