Direct Drive TT Options
If I were to buy a new TT in the new year, what options do i have, both used and new?
i've pretty much decided to stick with direct drive- it just works for me. unlike my poor rotel TT. i've pulled it apart a few too many times, and lost the use of 45rpm. not a big deal, but i'm keen to go a step further, and buy something a bit better if possible. no set budget as i really don't know whats out there. but don't really want to blow more than a grand, less would be better.
any ideas as always will be welcome.
Lee.
Whilst there is nothing wrong with sticking to direct drive you are not going to find a lot 'new', at least not for your budget, and not 'decent'. Most manufacturers going down the belt-drive route.
Your best bet would be to go to one of the reputable updaters of turntables such as the Technics SL-1200 and buy a modified example from them. Some even come up on that well-known auction site at times.
drummerman
540
Yes, a 1200 would be the obvious choice.
You could try and source an SP-10 in it's MK1 or 2/3 incarnations. They come with external power supplies and are built to broadcast standard. - A good example re-plinted should be within your budget. Tonearm extra and cost depends on model.
Third option would be to get a SL-10 or 7. The 10 is more popular, the 7 reputedly better. They are linear trackers and are ueber engineered though not quite in the way an SP-10 is.
Fourth, a SL-6 may be all you need/want. It measures almost the same as the 10 and 7 and is just a little bit more light weight. Looks good, sounds very good.
Cartridge choice is a little bit more limited for the linear trackers but very good ones from the main names are available as are after market shibata/gyger etc tipped ones.
Finally and I would love to add one to my collection is a Garrard 401, an idler drive. You will need to completely refurbish an original (or buy it that way, there are a few specialists). Imo a stunning piece of engineering and there are some lovely looking examples around. A turntable for life? Probably. You again should be able to get a refurbished unit within your budget but probably without tone arm. Second hand prices just increase all the time.
Hope this helps
regards
drummerman
540
ifor said:
SL-QL1 and SL-DL1 are also worthy of consideration. More so than the SL-6 I believe.
... but the SL6 looks/feels lovely and the direct track access is pure genius ... well, at least was back then.
The SL-QL1 looks a bit like the unwanted love child of a 1200 and SL-7 :)
regards
It does a bit doesn't it. I had to Google them as never seen one 'in the flesh'.
Whatever though I would certainly advise the OP to consider any of those listed so far but be very careful on where he buys from, could end up with a whole load of grief.
As a finsal note I'd say if your going direct drive look out for 'quartz-locked' in the description to.
Also agree that the lovely SL6/10's have very limited cartridge choice, as has already been mentioned, and this fact alone has kept me away from them.
thanks for all the responses so far, most of which seem overwhelmingly in favour of a technics deck of some description. I shall keep my eyes open, and do a little research, and see what sort of thing i can find.
iMark
Dual made some very good Direct Drive TT's in the late 70's and early 80's. I'm pretty sure there's a few of them knocking about somewhere. Look for model numbers like the 701, 704 and 721.
I found this one on Ebay and that seems to quite reasonable. This 714 is not as refined as the other ones but not a bad TT at all.
http://www.ebay.co.uk/itm/Dual-CS-714Q-Quartz-Locked-PLL-Direct-Drive-Semi-Automatic-Turntable-/261652866073?pt=UK_AudioTVElectronics_HomeAudioHiFi_Turntables&hash=item3cebb9e419
