I think you can:HI.
I have a few questions about daps.
If i bought a fiio m21, can I transfer via usb 3 from pc to the dap, but specifically to the installed sd card?
I think you can:HI.
Yes, shouldn't be a problem. If PC doesn't recognise the DAP via USB connection in the first instance, I believe FiiO has USB drivers you can download from their site.HI.
I bought a usb 3 to sd card dongle(sandisc), so hopefully that will ensure it works.Y
You can also use a USB SD card, if your PC/laptop doesn't have a SD slot, to download your music files directly to SD.
I bought
Thx.
