Different speakers for different flor coverings?
I need new speakers. I am moving house and there is a large room that indeed AV speakers for. The room is 27 by 17. My amp is a Sony DA2400ES. I am thinking of getting Monitor Audio RX6 AV12 speakers. Two questions.
1. Would they be a good match for the amp? If not, any recommendations.
2. Would the choice of speaker change if the floor was carpeted or wooden flooring?
Many thanks
Overdose
279
I don't know that your speaker choice would change, but I would recommend avoiding large expanses of reflective surfaces wherever possible. You'll potentially get nasty reflections and phase issues.
Then it'll be down to the clinic. ;)
CnoEvil
556
11
Hi there, and welcome to the forum.
Your room acoustics will usually have a profound effect on how the speakers will sound. Things like carpeting, curtains and soft furnishings will deaden the sound. A sparsely furrnished room, with laminate flooring and large area of glass will make the room echoey.
Only you will know if you like a speaker with your particular room acoustics.
