Desktop speakers
I need a pair of new desktop speakers.
I narrowed my list down to the following speakers, but can’t make a choice. Because there aren’t many reviews from some of the speakers and i can’t hear them play.
So maybe some of you can help me.
  • Audica MPS 1
  • Audioengine A2
  • Scandyna Micropod SE Active
  • Lars & Ivan BoBo + Isofa
I can get a nice deal on some of the speakers, so there is no real difference in costs and i think that speakers like the Audioengine A5 are to big.
I would buy KRK Rokits over any of those.
EDIT: LOL guy above me snaked in !!!
The Eclipse speakers might be worth checking out. There's also the Focal xs which can be found cheap sometimes
  • Audica MPS 1
  • Audioengine A2
if you're after performance I'd save for a little bit longer and get myself some Adam Audio Artist 5 (or Artist 3 if 5 is too big). all you need is a USB cable to get you going. for some GBP 780 (with matching desktop stands) you'll get really hi-fi sound. believe me, there's a difference between desktop speakers.
but if you want something to play in the background most of the I wouldn't bother with Adams. they're way overqualified for such a job.
Not sure what your budget is but I got the B&W MM-1's a few weeks back and they're superb
