DENON Standby and Idle Power Consumption
Messiah
205
10
18,795
I cannot see the CD player and Tuner using any more power than the amp in standby and that is rated at <0.2w
As for idle this will also be very minimal.
As for the SACD player I would recommend demoing the two if possible and then decide if it is worth the extra money.
MAre007
Messiah:
Where I live, there are very few places where I could listen to different HI-FIs and Denon is not as common as HK, SONY, Pioneer ...
So I'd be interested to get more information from you.
About standby: currently I own a Pioneer F-504RDS tuner which uses 5,5 W when in standby. Denon's higher quality components usually declare a low standby consumption, but not the low-end ones, so therefore I wonder why ?
ASK THE COMMUNITY
