Denon POA-T10 Power Amp - Can replacement 12v trigger cables be bought?
I'm looking at buying one of these second hand for roughly £170 and need to find out if I can somehow replace the missing 12v trigger connection that would have switched it on (I think). Can replacements be bought? Does anyone know?
Andrew Everard
1,878
Is it a normal 3.5mm mono-type jack connection? 12v trigger connections often are. If so, I'm sure Maplin or somewhere similar will have a patch cable to suit.
