- Aug 10, 2019
- 2,556
- 4
- 0
SOUND PROBLEM
My Denon DVD 1940 produces a fantastic 1080i Picture-better than 720p in fact. Watched 'The Fog' original version this evening and it was absolutely great-The blacks and detail were wonderful for a 1979/1980 film
I have my 42inc Plasma and the Denon connected via HDMI, I have also connected the Denon with my Exposure Stereo Amp with QED2 interconnects.
However the speech/Lip movement of the actors isn't entirely synchronised with the sound I get from the speakers via 2.1 channel stereo and I would like to know if this can be achieved?
If I turn off the amp, and just hear through the TV , then everything's fine as I guess it would be seeing as the HDMI cable carries both the picture and sound.
The 2.1 sound through my Analog amp and bronze2 Monitor Audios is great-Speech is crystal clear, but in order for me to enjoy the experience more I would love to be able to see the actors lips move in line with what they are saying.
Incidentally, the Sound output on my player is set to HDMI Analog 2.1-Is this right?
I've also got PCM and Bitsream but don't know which setting to use?
The instruction book is useless-can't understand it!
PICTURE QUESTION
When I change the HDMI output to 720p on the display panel , while the DVD is playing it doesn't show the small 'p' for progressive scan on the display. However, if I go into SETUP and change the display settings to COMPONENT PROGRESSIVE the small 'p' does show up on the display but then I haven't got the player connected to my TV with COMPONENT Cable....Just HDMI
However I love the 1080i picture output ( I don't have a 1080p TV).
Meanwhile, therefore is it a 'CON' of the machine itself in that the only way you can watch in either 720p or 1080p is if you connect the DENON to the TV with a COMPONENT Cable instead of an HDMI cable?
Finally, does anyone know if you can change the HDMI output via the Remote Control as I only seem to be able to do so manually by getting up in pressing the button the display.
Can anyone advise...Cheers
PICTURE QUESTION
