C cse Well-known member Mar 3, 2008 97 5 18,545 Dec 5, 2009 #1 How do you delete music from your ipod nano?
B basshound Well-known member Sep 23, 2007 116 0 18,590 Dec 5, 2009 #2 When in Itunes there are tick boxes against all the tracks, if you untick the tracks you don`t want and then sync the nano it should remove them.
C cse Well-known member Mar 3, 2008 97 5 18,545 Dec 5, 2009 #3 Thanks, but how do you synch the nano?
B basshound Well-known member Sep 23, 2007 116 0 18,590 Dec 5, 2009 #4 Open Itunes,plug in your nano and it should be listed on the left of the screen,click on it,select/deselect the music you want and then click the sync button at bottom right.
