I'm looking for speaker suggestions. I have a Bel Canto S300iD amp (internal DAC), much better than the Cyrus XPD which I tried last week. I currently have Epos M12.2 speakers which are brilliant but are probably holding the amp back at this level. I've read all the reviews etc. with regard to speakers at my price point, few seem to specify which speakers work better in smaller spaces. I'm looking at 2nd hand or very good ex dem deals, my budget is £700 to £900. My room is 4x3m with high ceilings, wood floor with rug, thick curtains, fairly average. The speakers are 2m apart and just over 2m to listening position. They have plenty of room to the sides but one speaker has to be in front of the fireplace so there isn't much room behind it. Music is extremely varied, volumes are low to medium, I like reasonable bass but would value tight bass & detail more highly, I have no preference between floor standers & stand mounts but I'm wondering if a sensitive floor stander might be better at my lower listening levels?
So far I've ruled out ATC's which (I'm told) need space & a bit of volume, also I'm not keen on the looks. Please feel free to suggest anything you feel may suit. Cheers!
