Dali Zensor 1 (wall fitting) and Dali Zensor 3 (Stands) advice needed
danbeatles78
27
want to add these two speakers into my AV setup, use the zensor 3's as fronts and the 1's as the rears
i need help/suggestions with the brackets and stands, can any of you fine people point the way :)
Dougal1331
69
22
if you can find the 'Dali Zensor 3 owners' club' thread, a couple of folks discuss stands there.
I use Apollo A4s personally, but there are several others worthy of consideration...
Blackdawn
88
I would suggest stands such as the ones covered in the Zensor 3 thread. There are other such as the soundstyle z2 or Atacamas. I would use the Zensor 1's on the wall as they have the easy hanging screw hole the back. I use my Lektor 2 speakers on the wall with good results. Not many budget speakers seem to include this easy feature - much easier than a bracket.
matthewpiano
Stand-wise, the Zensor 3s respond to being on something very solid, weighty and stable. I use some Mission 79-series stands, which you might be able to pick up second hand. They work very well. Otherwise I'd suggest Partington Dreadnoughts.
