Dali Ikon 6 Speaker Package
another annoying question for you all.
If anyone knows the above system well, would you consider substiting the rears with the ikon 1's?? Or will replacement of the on wall rears change the system hugely and take away what makes it so special? I cant hang wall speakers due to being in a rented property.
fr0g
445
Gander:
It will sound great, but I would go for the Ikon 2's which are about the same price as the on-walls, and a great speaker in their own right.
PaulShaw01
18
I have the Icon 1s at the rear, and they sound great. The Icon 2's will sound better, but they are big!!!!! The issue I had was that I wouldn't be able to get them past my wife as I already have the icon 6's at the front.
In saying that, if I find a bigger home then I would get the icon 2's and use the icon 1's for 7.1
Overall the sound is still immense using the icon 1's!!!
