Dacmagic with reversed phase
Peter Larsen
106
Hi, I have been experimenting with reverse phase on my DacMagic, and actually found that some recordings sounded better that way. Most often the voice was much more precisley placed in the middle of the soundstage and the sound seemed more open overall.
However I do not understand what is actually happening technically. Is it the same as if I reverse + and - on my speakers making the membrans move inwards instead og outwards?
How can I test whether a CD is recorded with reversed phase?
shooter
210
Not sure if you can test it Peter per se. It is true though that some equipment sounds better reversed. I do this with my amp and speakers as it gives better results similar to what you have found. Also its widely known analog equipment can work in this way also. I've tried reversing poles with the TT but the soundstage gets smaller this way for me but the speaker/amp switch does.
Enjoy it.
