DacMagic upgrade
nbaptista
18
Hello to all,
I´ve got a Cambridge DacMagic and so far I´m happy with it!However I´m a big fan of Rega and so when the Rega Dac was released I thought"Why not give it a chance?"Do you think is worthwhile to upgrade my DacMagic to a Rega Dac or no?I would like to get feedback from Rega owners!One of the reasons I am not so excited with the upgrading ideai is that sometimes I feel that Rega sound is a bit veiled!
The Rega should be a good improvement, but also try the Musical Fidelity M1......if possible, get both home for a demo.
Cno
I've listened to both the Rega Dac and Cambridge Audio DacMagic and to be honest, the Rega Dac is more musical. However, I feel the Cambridge can hold its own. It depends on what you are using your dac for mainly. If it's mainly for music, I say give the Rega a go. However, if you are using it for a myriad of other things like PS3, Blu-Ray etc., just stick with the Cambridge.
Just my opinion. Best to go give the Rega Dac an audition.
nbaptista said:
Hello to all,
Hi nbapista
How would you describe the performance of your existing system?
What do you and anyone else who is also likely to use the system listen to?
What source/s do you use?
Your amplifier and speakers are?
The interconnect/s and speaker cables are?
Your overall budget is?
What areas of improvements are you looking from a new dac over the DacMagic?
What kind of presentation are you looking for the system to reproduce with a new DAC?
All the best
Rick @ Musicraft
All the best
Rick @ Musicraft
Mostly I use the stereo to listen music!I´m using the USB PC output connected to my DacMagic to listen FLAC and I have a 340 c transport!My amp is a Densen B 110 and my speakers Epos M 15, so I guess I could do an upgrade to my Dac . The IC is an Atlas Equator and spk cables are Audioquest Midnight!
jaxwired said:
You're a big fan of Rega but you feel the Rega house sound is veiled? What makes you a fan then? Veiled but still great?
Not veiled,but sometimes a bit veiled!I like the Rega smooth sound !
