- Aug 10, 2019
- 2,556
- 5
- 0
I have recently bought a DAC Magic which is connected to my laptop using a USB lead. I listen using itunes and the mp3's are mostly VBR or 320 kbps. The sound is superb!
Now I believe i can connect using the s/pdif socket (3.5mm / minijack) to toslink connector, my question is:
Will this connection method give me an improved sound bearing in mind the bit rate, and if so, is there a recommended lead available?
I have had a look on the internet but am not sure I would be buying the correct lead.
Opinions are graciously appreciated.
Ta
DAC connected to Arcam FMJ A32 amp / Rega R5 speakers
Ta
