DAB amplifier
I have a Marantz system (CD6003, PM6003) with Keff Q30 speakers. I also have a Denon TU1800DAB but the PM6003 is analogue only. Should I buy a digital amplifier and if so which? Or should I dump the Denon and go for a separate DAB radio set up?
Colin
Dingwall:
Colin
Not quite sure I know what you are asking here. I have that same tuner, its a great bit of kit. Do you want to connect it via the optical out or something? Why not just connect it via standard phono?
You shouldn't need to change/add anything.
If you want get the best from your tuner, ensure you have a good aerial and use a decent pair of analogue interconnects.
Remember, your CD player is also a digital source - does that require a digital amplifier..?
You have a nice system - enjoy it!
