Cyrus : differences between CD players Xt SE and SE2
Benedict_Arnold
661
Some people reported problems with the slot loading mechanisms on early CD XT-SE models, which I think were fixed by Cyrus under warranty and did not affect later CD XT-SE units. I think the SE2 was basically the same as the fixed CD XT-SE with a software upgrade as well, but check with Cyrus.
If you're buying a used CD XT-Se check it's not been affected by the loading problem and / or has been fixed under warranty.
bcostacurta
Thanks to all for useful answers.
I bought a second hand Xt SE, and now better understand the differences with its successor SE2
I'll contact my local Cyrus resailer for faisability of the sofware service update to SE2 (is this a local intervention ?).
I'll also query about the available mechanical / technical upgrade path (via a return to the factory) as many Cyrus products are upgreadable.
Thanks for your attention.
Bruno.
bcostacurta
Upgrade from SE to SE2 will cost around 400-euro (circa 335-gbp).
In September 2013.
Worth waiting about the upgrade CD Xt SE to the new CD Signature model.
However currently my vendor (in Luxembourg) does not have more information, or even possibility for a such upgrade, from Cyrus.
Bruno
