cyrus cd6se
i own a cyrus cd6se, 7 amp as pre, 8 power, 2 psxr, cyrus cables, monitor audio rs6, i am willing to part with 2k on new speakers i like what ive read about wilson square 2, pmc fb1i, atc 19, proac 140, does anyone reconmend speakers except spendor.
thanks
lowesy:
thanks
They'd all be on my list, along with Sonus Faber. Why not Spendor?
you could also try focal - lovely speakers although they sound best on the end of neutral/warm electronics so not sure how they would sound with the Cyrus kit
Are you biamping at present? If not, the pre-section in your C7 will very much be restricting component once you replace your Monitor Audios.
Id recommend you check Dynaudio's range as they go well with Cyrus.
lowesy: i own a cyrus cd6se, 7 amp as pre, 8 power, 2 psxr, cyrus cables, monitor audio rs6, i am willing to part with 2k on new speakers i like what ive read about wilson square 2, pmc fb1i, atc 19, proac 140, does anyone reconmend speakers except spendor. As previously mentioned, your 7 integrated will be holding back your system. Integrated amplifiers sound ok as pre-amps and provide an easy upgrade path, but always go for a dedicated pre-amp wherever possible.
As for the 8 power, as good as it is, you may find it not quite being man enough for a couple of the speakers you mention, which may require an X-Power, or even Mono X's in some cases.
All good speakers according to reviews, the Square 2s are especially impressive but I haven't heard the ProAcs or PMCs, although I have some small ProAcs which I love
