- Jun 6, 2013
- 5
- 0
- 0
I have some new subwoofers, mostly for music playing, so i'm not worried about sub sonic trembling, however my receiver will let me set the crossover up to 200Hz. I want to set it that high, but the subs crossover has 120Hz as the highest setting. Will it be bad to pass it that high?
The subs are monitor audio RXW-12's so they are of a nice high quality.
I am aware that the higher I crossover, the subs will have to produce certain noises that they wouldnt normally play, but i notice in some somes that certain sounds that are supposed to be in the bass region are losing there intensity cause of the crossover, (sounds in like the 120-180 Hz range i assume) and since i'm expecting them to puch out these sounds, it sounds funny when it crosses over.
So will it be damaging at all? or is it just that it may not have good response in the 120-180 Hz range?
I am assuming that these subs will have much better mid-bass response than others since they are sealed subs, so I am also assuming that they should respond between 120-200Hz, but I dont want to damage them.
