Cowon iAudio E2, Any good in combination with a Grado SR80i?
This mp3 player seems perfect for me, but i do have one question and i hope someone can aswer it, if you have a high end headphone like the Grado Sr80i and connect it to this mp3 player, will it be a good match? I recently bought a Sandisk Clip Mp3 player who is actually VERY simular to this E2, but the only downside is that the volume level on the Clip is very low, even at maximum...will i get the same with the E2? I want to enjoy FLAC files on a reasonably high volume with my Grado headphones...i know the Cowon has FLAC support, but how high will the volume levels go? Does anybody know?
SteveR750
730
137
19,070
If it helps, I have used a pair of SR80s with an ipod nano (1st gen I think) which has a limited max volume issue, and the combination isn't loud enough to be of any use other than in a quiet room. I know its not the E2 but if you have listened to an ipod then it might give you a useful reference.
Thank you Steve for your reply. I experienced the limited max volume issue with the Sandisk Sansa Clip and you're right that you can only enjoy music when there is very little background noise, like a quiet room. Now i am looking for a MP3 player that gives me the chance to fully enjoy my Grado headphones, but i have no idea which one i should go for. To bad that the E2 is mostly available on the internet at this point in time, because otherwise i could try it out for myself.
A classmate suggested the new Archos Vision (5), which is a expensive bit of tech, but is spending more than 100 pounds the only option for me if i want to enjoy FLAC music files with my Grado headphone?
