Connecting wii to surround amp and tv
mattjax05
230
On behalf of my friend.
Currently he is using a composite connection with the rca cables (red, white and yellow) to connect the wii directly to the tv. However he wants the sound through the amp and I suggested that he gets an rca extension and connect the red and white cables to the amp (the tv would then just have the yellow connection), is this correct?
Would anyone recommend purchasing a component cable for a better picture? And if so can he use the same approach for the sound as above (his amp does not upconvert video signals)
Matt
mattjax05
230
VoodooDoctor:The picture through component is far superior to composite so it is a worthwhile upgrade. He could then use RCA extensions to get the sound.
Thank you.
I bought the oficial Nintento component cable and was amazed by the difference in picture,
Mine is connected direct to the TV (Pana 42PZ80), but will soon be connecting it to my amp just purchased, I am waiting for till I can afford surround speakers before I rig it all up.
Paid £25.00 for mine but sure you can get one cheaper, it already comes with audio connections( 3 for picture, 2 for sound).
Leahandanna
matengawhat
695
15
18,895
its a massive improvement - you'll be amazed at how much clearer the text on screen is
£9.00 from ebay (Madcatz, new) from a pro shop. I got mine in 2 days.
mattjax05
230
Big Chris:Yeah. Don't buy any old component cable, as the Wii end has its own plug connector.
Yeah I did mean a wii specific cable - putting their own design on the connection will certainly increase Nintendo's revenues - well played Nintento!
Thanks again guys for some suggestions.
