How do i connect my tv to the internet ? do i just run a lead from the tv straight into the back of my v+ box ? or do i need to plug from tv to router , then router to v+ box ?
oh it needs to be wired by the way !
What TV is it (just to check it's internet enabled)?
All you ought to have to do is plug it straight into the router, no V+ box connection required (not for the internet bit anyway, obviously you need to connect it to get cable 🙂).
Right the tv is lg50pz570 . I have v+ box in my tv unit which has internet socket in the back . My router however is upstairs in the bedroom which is linked into the virgin moderm . I have my bedroom sony 26ex320 hard wired into the router so i can get internet tv etc upstairs . As my router is upstairs i will need 30ft cable leading from that to my downstairs lg which is not possible . As my tv and v+ box are within 3ft of each other can i not just plug an internet cable from the tv to v+ or wont that work as it needs to be run through a router ? Is so i will just get another router to run from v+ to tv ?
