- Aug 10, 2019
- 2,556
- 4
- 0
I have recently bought a Panasonic TX-32LXD700 32" LCD and a DMR-EX77 DVD recorder which I aim to use with my Sky box (not a sky + or HD!) SIMPLE HUH! So why do I feel like throwing it all out the window?
Current set up as follows
LCD
Scart from LCD into Sky Box
HDMI from LCD into DVD recorder
Sky box
Scart from LCD (as above)
Scart from Sky Box into DVD Recorder
DVD Recorder
HMDI from LCD into DVD Recorder (as above)
Scart from Sky Box (as above)
I think I got the main aerial feed into the TV and then a aerial lead from Sky to DVD, if memory serves. It all seems okay, the Viera link is working which turns on the recorder and automates all that. I have the TV on powersave which does something funky with AV2 I think but means the recorder is pretty slow to boot up. When I push functional menu on the recorder remote and toggle the AV input so I can see the Sky channel I want to record the colours are really really strong, way to vivid and not at all like the normal picture set up when I watch Sky normally.
If you can offer some guidance and advice on how to set this all up so its works the best possible I will be grateful. I guess my main bug is the color when trying to record Sky, the rest I can live with so please help.
As you can tell - this is all a bit new for me
LCD
Sky box
DVD Recorder
