Connecting I pod to Reciever
Andy Clough
776
As you've got the Onkyo receiver, I'd suggest Onkyo's DS-A2 dock (£65) that will plug directly into a spare set of phono ins on the receiver, and gives you full charging and remote control of the iPod.
If you can spend a bit more, the Arcam rDock (£130) sounds even better, although it doesn't have a remote.
tommyb
87
It depends what you want from the connection and what you have already.
By all means by a dock if you want to chrage your ipod at the same time or remote control it.
If you just want to listen to it - get a good quality 3.5mm jack to phone lead like the ones here:
http://www.audiovisualonline.co.uk/dynamic/eshop_categories.set/ref/19/3.5mm-jack-phono/browse.html
I'm sure you can even spend more for a more technical lead! They just plug into the top where your headphones go and into the back of the receiver! Just chrage your pod normally as you have been doing.
