Connecting a single wire to speakers
Hello,
I have a set of warfedale EVO 30 (older type) speakers, these can be biwired/amp. I have a single wire but i lost the connectors whitch go between the two +'s and the -'s.
Is there a anything i can use to connect those +'s and -'s to gether, like a peace of copper wire?
Thans for repley.
Have you got any spare speaker cable? That will do the job
seasiders rock
7
yes speaker wire, or if you want to splash out qed, chord, russ andrews all sell jumpers...
i have the same speakers evo 30 mk 1 and at the moment trying to decide which sounds best, single wire or bi wired.
Just get some normal speaker cable and that will do the job perfectly, don't need to splash out on these rather pricy jumpers they do the same thing and will sounds the same.
ASK THE COMMUNITY
