I've been looking to get an HDTV since Christmas, but the pros and cons of the various models had me thoroughly confused. And now. helpfully, all the manufacturers have changed their ranges. I'm really sick of looking and just want to settle on a model, check it and hopefully buy it.
My requirements are fairly simple:
* 40 or 42" screen size.
* Budget is up to about £1500 but I'd REALLY like to spend less if possible - I want something that offers good value for money.
* Low input lag and great motion display for console gaming
* Great SD upscaling because I still watch a lot of it
* Decent viewing angle because no-one sits directly opposite the TV
Now, I thought I'd settled on a Panasonic GT60. But after seeing one demoed in Richer Sounds, I was bothered by two things. Firstly, Plasma generally (and the GT60 is no exception) seem to have a slightly softer, fuzzier, picture than LED. Cinemaphiles might like that, but I think I honestly prefer the pin-sharp images on LED sets.
The more serious issue is that I thought the motion handling was very poor. When watching the cricket, fast balls blurred and ghosted very noticably - to the point where when you should see one round ball, there were sometimes three blurred smudges on the set at once. The shop staff turned off picture pre-processing which improved the situation a lot, but not totally, but that had the knock-on effect of turning panning shots into a smeary mess.
I always read that Plasma gives a better picture. But I'm not an AV enthusiast, and our TV will get watched in all light levels, from bright sunlight to dark nights with the curtains shut. I need something flexible. And I'm a little concerned about stories of Plasmas adding £100/yr to energy bills, heating up rooms. And then there's that soft focus issue.
Can anyone help? I had a look at the W9 series, but the viewing angle is limited and it's right at the top of my budget. I am really so sick of going through the options - I would really appreciate some advice from the viewpoint of the average consumer looking for a good value, decent quality set rather than the hardcore AV community at whom most of the reviews seem to be aimed.
Cheers,
Matt
Cheers,
Matt
